Middle Seatbelt in the back
Does anyone know if there is a seatbelt for the middle back seat? anyone know how to take out the rear bench if there is one? thnx
Im pretty sure it has one in the back. I think it even has holes built in to the bottom part of the seat for the female end to poke out. As far as taking out the backseats....its easy. Right between your legs in the back seat on both sides there are simple hooks hiding under the seat. I find taking the seats out of cars are easy when we put in stereos and 4 6x9's in the back deck. This way is the easiest I think
Move both of the front seats forward. Get in the back floorboard kinda crouched down facing the trunk. The little hooks under the seat only come off if you push the seat in the direction of the trunk. So on both sides in the center push kinda hard and go diagnally up a little bit. I always crouch in the backseat because my wimpy little arms arent strong enough so I use my knees. Its not as hard as it sounds.
