THANK YOU! and also a 2nd Gen ES300 Headlight Question
Hello all!
First off I'd like to say great forum and that I've learned alot about my car over the last few years.
Most people on here spend alot of time and effort doing research online and hands on and are kind enough to share that information with detailed write ups and more.
Thanks again for all your help over the years.
OK, now my question was about 2nd generation ES300, specifically 1994.
Over the past few years I've wanted to clear out the turning signals in the head lamps after reading the write ups from here. Being the lazy person I am I never got around to it (hell I've been lurcking on the forum for about 5 years or so and finally decided to sign up, I know don't judge me!).
From my understanding (please correct me if I'm wrong) the later year ES300s 1995, 1996, etc...have a different headlight housing correct? Unlike the 1994, these headlamp section can be seperating from the turn signal section?
If this is true, would one of these type of headlight housings be a direct fit for a 1994?
If not a perfect fit would light modding be necessary or impossible or not practical for the amount of work required to fit these?
Or am I completely wrong on this one?
Thanks in advance ya'll!
I can't be too much help here, but I believe the later ES's (95+) have a different housing. It would probably be a lot of work just to clear your corners. You can do the oven bake method to open them and then clear the corners.
I have thought about clearing mine but I think the orange corners look better on my Dark Emerald Pearl than the clears would, IMHO.
Hopefully one of the more knowledgeable members here will chime in and provide some better input.
Good Luck!
Good Luck!
Good Luck!
Good Luck!
I'm pretty sure the housing is different as well. I think those 95+ housing are 2 pieces. One piece is the projector section and the 2nd piece is just the corners. I believe they use to make aftermarket clear corners that you could just swap out that 2nd piece?
Now figuring out if those 95+ 2 piece housings would fit in a 94 is the question.
I do agree with you the orange isn't bad looking at all, I'm just getting tired of the same look on this car since I've had it for so many years and just wanted to bring some new life to it.
Inorder to snap off the orange you still had to take apart the headlight right?
Also the headlight is one piece right not 2 like i thought?
Now I know I can purchase any 2/2.5 gen es headlight from a junk yard and it'll fit.
Awesome
The 97 ES300 headlights aren't compatible with our year ES300 either huh?
Thanks again.
eyezack, you are always a wealth of knowledge on exterior lighting. Yours look great and if mine was the same color, I would have already done it. I haven't seen any Dark Emerald Pearls with clear corners yet. If I saw one, I might change my mind.
How are your LED tails coming along?
Sounds like a plan. Another member on this forum was nice enough to PM me and give me some pics and advice as well. So with that info and the write up from here I think I should be in good shape.
Thanks again.
Thanks again.
As for the LED tails, its a very slow process. I'm taking 5 Upper div Chemistry courses right now and its taking quite a bit of my time sadly. I have it all figured out, just need to put it back together now
dante1616
12-21-07 06:20 PM
