turn signal ES300 / 96
ES300. 1996. turn signal issue
My left turn signal flashes fast. the right turn signal works fine.
I also noticed the right side is brighter than the left side when the turn signal is turned on.
I replaced the light bulb and the problem is not resolved. I checked the light bulb and both filament looked ok i.e not broken.
are the right and left signals controlled by the same flasher? if so then I can safely assume my flasher is fine.
so what could be the problem?
Any help you can provide is greatly appreciated.
Thanks in advance.
Thanks in advance.
nrusso3487
07-31-18 10:48 PM
