Power Steering Pump Removal 2002?
How challenging is it to remove the power steering pump on a 2002? Mine is squeeking when cold outside. Oiling w/ spray lube helps for a couple days but replacing the belt didn't make a difference.
It looks like a bear to get access to.....
I should add it only squeals when cold and has little effect of rpm when cold. It's not low fluid - it squeals all the time when cold regardless of cranking the wheel. Thanks.
BrittonJ85
04-28-10 10:39 AM
