White smoke coming from the exhaust 1996 es300
Hi guys, So i took my car out for a ride tonight and I noticed a faint white smoke coming from the exhaust for a while, does anyone know what this is? thanks in advance.
With that mileage on the original motor...
If the white smoke doesn't go away, it's usually a sign of coolant getting burned in the combustion chamber.
Pull some spark plugs out and inspect them.
A very clean looking(glossy) plug is a sign of coolant burning.
Also there is usually a tan residue under the oil filler cap if you have a seeping HG. And there is a distinct sweet smell coolant makes when it is burned in the combustion chamber.
If you find that it is a SHG, you might as well put a newer engine in it rather than replace the HGs.
