1997 Lexus ES timing belt
03-09-10, 11:02 PM
does anyone know how much a timing belt would be to put in a 97 lexus es? how would you know if you needed one?
03-09-10, 11:06 PM
have you had it replaced before? how many miles do you have on the car?
03-09-10, 11:07 PM
Yes. I drove the LFA.
Toyota/Lexus recommends the timing belt package every 90k miles...
Price depends on where you go...
03-10-10, 06:31 AM
On top of the other 2, you do NOT do just the timing belt. You also do:
Water Pump
Tensioner
Cam/Crank seals
03-10-10, 12:39 PM
If you are just doing timing belt...2-3 hours.
However, you should also replace the spark plugs.
And on top of what the other guys said, you should also replace the idlers, valve cover gaskets, and thermostat.
Klogan
07-26-19 03:12 AM
jygesq
16
06-24-17 02:40 PM
lnguyenh
04-09-11 07:28 AM
blaktino47
11-12-10 01:56 PM
Ed Lalo
02-10-09 10:45 PM
1997 ,
300 ,
97 ,
belt ,
belts ,
change ,
cost ,
es ,
idlers ,
lexus ,
problems ,
replacement ,
security ,
setting ,
timing
