custom lighting in the AC console
I have a ton of lights out and they are the stock greenish color wondering if there is a FIX or if anyone knows how to change these to another color or just to replace period.
There is a very good detailed DIY write up if you do a search.
I haven't done it myself but have been thinking of doing it too.
If I remember reading correctly, there is 5 plug and play bulbs (behind the buttons, might be same bulb size as behind the clusters) and 3 bulbs you'll need to solder in (behind the big display).
I think the green color comes from a diffuser on the bulb, so if you remove the diffuser or place a different color one it should change the bulb color, or go with LED.
Good Luck!
jasonviper
06-02-07 11:37 PM
JerseySC
08-29-02 03:58 PM
