IS T-IV backwards compatible with DEXIII and is Mobil 1 a safe alternative
Hey everyone,
My tranny fluid is still somewhat red but the edges when put to a piece of paper are dark which may indicate its time for a tranny fluid drain and fill. Its a 97 es300 so the manual calls for DEXIII, but I prefer not to put in the SuperTech Wal Mart brand or anything that;s not "brand name". I have an unopened extra quart of Mobil 1 ATF that's a few months old sitting around from when I did my power steering change, so I was considering using that, but part of me also wants to stick with OEM spec.
I made a few threads about this in the past and was leaning towards Amsoil, but at this point I think I want to just go and pick it up from the store and Mobil 1 and T-IV seem to be the only good candidates.
My question is, is that if I do say 3 drain and fills over the course of a few months is it safe to have Mobil 1 mixed with old tranny fluid. And on the same note is T-IV backwards compatible and safe with the old DEXIII fluid.
The goal is safety from failure haha.
Thanks for your help!
Super Moderator
Yes, you can mix the Mobil 1 ATF with your old tranny fluid. I had to do the same thing when I changed from Type IV to Amsoil. I recently changed from Amsoil to Redline D4 in part because I want a change but also I've been studying viscosity differences and oil analyses and my two finalists were the Redline D4 or Royal Purple's Max ATF. The Mobil 1 is somewhat close in spec to the Type IV (they're actually both Exxon Mobil products), but with my RX300 having a modified tranny and torque converter (that runs a bit hotter) I need a bit better protection.
SuperCoupe400
Performance & Maintenance
05-09-08 08:07 PM
alternative, atf, backwards, compatibility, compatible, fluid, istiv, iv, lx470, max, mobil, purple, royal, tiv, transmission, viscosity
