Lookin for a 1994 es300 pinout ((help))
Ok so after a couple of nites of google n yahoo search and readin through a bunch of threads, i still havent found a link or anything of where to find the ecu pinout for my 1994 es300. can anyone help me out or even better hook me up with the pinout??
ASG14 you r da man bro..... found exactly what i needed, all the wires are identical. thanx alot bro!!
one more question!! how do u retrieve ur CEL's from your ride, i tried all 3 plugs(1 under da hood,1 under da dash, 1 in the fuse compartment) n nothing!! the one in da fuse compartment i used my obd2 scanner n it keeps givin me an error connectin message and the other 2 when i ground the te1 n e1 the light in the dash dont flash.
Thats what i thought also... so i went n cheked 2 other obd2 vehicles i have and it worked fine. and i dont have a cheap scanner either i have a scantron9180. the crazy thing is that, even if i disconnect the batter to reset the ecu as soon as i turn the key the chek engine light is still on. could it be the ecu?
Nah, your fine.
I have a feeling you may be on to something with the ECU. Due toi the fact your CEL comes on imediatlt, and the OBD2 system is not working, it seem to me there is either a short int he OBD2 wiring somewhere, OR the ECU is going bad. What "exactly" does the scanner say when you hook it up?
Also, rather then unhookign the battery, you can also simply pull the EFI fuse for a few seconds in the fuse block JUST behind the battery. That will reset the CEL.
its givin me a "connection error"chek connector "would i like to try again" i pulled out my ecu today and gonna try out another ecu from this guy partin out his es. so hopefully ir does da trick and im able to find out wat codes its shootin out. wish me luck!! lol.....
ps. i opened my ecu up just to see if i can spot anything outta da ordinary n get sum pics for future reference
Lmao@ brembo blacks!! anyhooo k im back with a progress report. so i found another ecu at the junkyard, i took it off a 96 es300, came home plugged it in and the car started fine with no chek engine light until i rev it, so i plugged in my scanner n retrieved 4 codes. random misfire, misfire in cylinder #5, misfire in cylinder #6 and a p0450 dat i forgot wat it means lol.... so now im im tryin to figure out the misfire situation. the car idles fine but i can still feel the misfire. i took the 96 ecu out n dropped in the 94 ecu (original ecu) and the car starts up fine, smooth idle, n no misfire, but wants to die out when i go to give it gas, n the chek engine light on. so i plugg my scanner in n i get the error connecting message. so now my question is...... does the diference in years even though they r the same engines make a diference in the ecu programing? i kno the 1994 es300 is a v6 3.0l mfi dohc and the 1996 es300 is a v6 3.0l sfi dohc. would dat be the diference?
96 ECU and 94 are different. In fact, I think the 94, 95, AND 96 are different. And to add to that, there is both Fed and Cali emmisions ECU's. The Camry SE ECU is the same as the ES300 I think, but ONLY the SE trim.
Make SURE the part #'s on the ECU's match. If you want, give me your ECU part number and I'll find it on ebay for you. I like searching for crap, lol.
