3rd Gen ES300 Projector Retrofit
im not sure what you guys are talking about, but doing the retofit isnt that bad. just take your measurements and it'll come out close enough to use the factory adjustments to tweak them.
maybe i just havent run into a difficult retrofit yet.
did you do the projector retrofit to the factory hids? i was wondering how that'd turn out.
That looks nice on that black one above with the HID housings. My 00 ES300 has factory HID with the autolevelling system. As much as I love the beam pattern of projectors I think im going to just leave it as is. I am used to OEM high end HID projector equipped cars like my 07 TL-S with bi-Xenon and I will say I was pleasantly surprised at how nice the output is of my OEM HID's in my 00 ES300. The autolevelling feature is kinda cool to.
I have done several retrofits in other cars I will agree with the majority it is a LOT of work and to do it perfectly requires a lot of time and patience.
James
James
^^ You don't really need a garage.
A buddy did a SL500 IIRC, bi-xenon setup on his Lancer, purely because he had a ton of projectors lying around, he has the time, and the patience to do it.
It took him a whole 3 hours to complete... The ES300, he tells me would be even easier since the lamp is simple and easy to work with in terms of room.
I might be getting a 3series retrofit done... not sure yet.
01LEXPL,
If youre going to use up all that time to do a retro, id suggest not doing any of the e39/46/55 projector setups. They are extremely weak compared to other stock hid projectors. cutoff is fuzzy, lighting width is short, light loss with open projector is significantly high as well. anyways, goodluck.
for the other guy asking about how to do a retro setup, go to hidplanet.com.
Charley
Charley
