3rd Gen ES300 Projector Retrofit
#31
01LEXPL,
If youre going to use up all that time to do a retro, id suggest not doing any of the e39/46/55 projector setups. They are extremely weak compared to other stock hid projectors. cutoff is fuzzy, lighting width is short, light loss with open projector is significantly high as well.
#32
Yes, i have been hearing the same results for FX projectors as well. Very commonwith lens swaps as well. But you can never go wrong with s2k/ap1 projectors or sc430 projectors as well. Tl is very nice as well, but i only have experience with sc430/e30 clear lens setup. It is quite beautifully at night. So much more output than just about all stock hid projector setups.
Goodluck
Charley
Goodluck
Charley
#35
While we are on subject for retrofits, even though my 2000 ES has OEM autolevelling HID's I could still easily do a retrofit but I have a question. I noticed sometimes when going over a bump I can see the beam shake a little. I know this is common but if I can see it relatively easily with a non-projector cutoff I would imagine it would be pretty bad with a projector that has a super sharp cutoff. I wonder if the play is in the autolevelling mechanism or the bulb holder itself.
I wouldnt mind tackling a projector retrofit would be pretty cool along with the autolevel.
James
James
#37
James
#38
No thats what would be really cool about it is to keep the autolevel system. I see what your saying and why to get rid of it but I think thats an awesome feature (and it looks cool when you start the car when they move lol). I guess if I were to look into it more I could probably find out where the extra play is without too much trouble. Its either gotta be the bulb holders or the aiming mechanism. Anyway, it could be a cool project however I will say for these headlights not being projectors I am very impressed with the output.
James
James
Here's what i'm thinking. The current OEM autoleveler probably would not be able to hold the weight of a projector & shround, as all it holds now is a bulb that weighs nothing.
My realistic suggestion is to get the RX330/350 headlights with AFS And retrofit those into your current housings. This way they will retain the up/down function. I'm not sure if the side-side movement would work [as there's probably sensors for that].
#39
Alrighty.
Thanks,
James
tiguy99
Lighting
21
11-05-10 09:20 AM
