Will these tires\17" wheels fit the 98 es 300?
17" RWD:
Front: 225/45/17, 17x8 +45mm
Rear: 245/45/17, 17x8, +45mm
They are off a 2010 IS250 RWD
thanks
thanks
Rear tire is too bulky. I would reduce it to the 225/45R17 all around, as that it what i have now. And it will throw the speedo off, and turn at a different rate then the front... in other words get the same all around.
Offsets - no no.
You need four [4x] 5mm spacers all around to bring down the offset to an over all ET40.
With an ET40 an 8" wider rim will clear no problem, actually you have a little bit of room in the back to clear the strut and tire. That's why i urge to reduce the size since i have a feeling that tire will rub in the back... I ran the ET40 on multiple sets of wheels.
Offsets - no no.
AliasLexus
Wheels, Tires & Brakes Forum
02-05-16 09:11 AM
