Head Light cover has condensation on them at all times?
My head light cover, like the glass, has condensation on them and its looks foggy. It looks like i just sprayed them with a hose and the water is just sitting there and trying to evaporate but has no place to go.
Anyone else have this problem or know how to fix it? If i take them off and wipe them clean, do you think perhaps that will fix the problem? Thanks a lot.
Could you post a picture? That'd definitely help with describing your current situation. What it sounds like to me though is that your lense is dirty and perhaps you may need a headlight restoration kit. I used a 3M resoration kit on my 2ES and it did wonders.
I seen a restoration kit at Wal-Mart for like 20 bucks might go n grab that... but ill look around on the net n see whats good out there. What are your thoughts on what I could do since youve seen the pic
Thank You
Once that is done, look at the headlights again. If they are yellow, take some metal polish and smear it with no pressure on the outer lens. Let it sit for 5-10 min and remove. All the yellowing will be gone. I use Blue Magic Metal Polish
Good luck bud
Your problem is on the inside of the lens. You either have a bad seal, or the headlight air vent is blocked. There should be a vent with a rubber attachment in the back of the headlight that lets moisture out.
The easiest thing to do would be to to bake both headlights in the oven, take them apart and reseal them again.
Or sometimes, turning on your headlights will dry them out on the inside, but if you have a bad seal, it will keep coming back. Also, if you live in a humid area, that doesn't help either.
I was reading that in the owner’s manual, that there was a vent. I havent looked but deff will now. LOL bake them? seriously? Just take them off and put em in the oven? What temp n how long then?
I have no idea what "chrome" you guys are talking about? Is it around the head light?
How do you "smoke" them out or paint the "chrome" black?
Thanks guys, appreciate your feed back a lot!
Yep definitely pass on the 3m kit for now. I think what they mean by baking your headlights is to put them in the oven for 2-3 minutes at 300 degrees (long enough for the sealant to start to get soft). Hopefully by the time you take them out they'll be dry on the inside too. If not,take the headlight apart using a wide flat object, such as a trim remover. Take your time with this. It'll be frustrating. If it seems that it might not be budging use a heat gun (or a hair dryer if you don't have one) around the edges. Next, after you've opened it up, it's time for you to clean them up. When you're done cleaning them, put the headlight back together. Again throw it back in the oven for a couple minutes. I'm not sure how good your seal is at this point but if you inspect the area and it doesn't look too good apply a layer of 100% silicone around the trim area to seal the area just a bit more. Next use as many clamps as you can (the more the better) to clamp the headlight closed in as many areas as possibly. By doing this it'll make sure you have a nice tight seal and so you don't get any holes or cracks for water/moisture to get in in the future. Finally after it's done drying, reinstall your headlights and hopefully no more condensation in the housing!
Good luck.
Good luck.
Basically, preheat the oven to around 250 and leave each of your headlights in there for 5-8 minutes. Do one at a time. After you take it out of the oven, carefully pry it apart with a large flat head screw driver. You might have to put back in the oven for it to completely come apart. The sealant will become very soft and you will be able to pull it apart.
After you are done cleaning or painting or whatever you want, apply 100% silicone around or on top of the previous sealant and press the two parts back together again. Preheat the oven again and put it back in. Everything will get soft and you can press it back together firmly. You should not have to mess with it ever again. Also, make sure the air vent is clear on the headlight.
