es300 problem plz help!
Ok, so my es300 has been sitting in the garage for a few weeks and i did not disconnect my capacitor and other stereo equipment, so the car died. Me being an idiot jump started it the wrong way. crossed the cables and blew my amp fuse. Once i jump started it the correct way, the car started up fine. BUT. I blew some fuses in the process. I thought at first it was just the amp fuse..but come to find out, my brake lights will not work, no blinkers, no dash lights, no window power, no seat power, basically no other electrical power other than headlights and dome lights. i put in a new battery and car cranks good. Just can not get car out of park and no other lights work. No stereo, no brakes, only headlights and domelights. Did i blow a relay fuse? or worse?
check the relays....jumping a Toyota the wrong way usually fries a relay or two (varies by vehicle)...if you have access to the electrical wiring diagram for the vehicle, you can find the common relays for these systems and pinpoint which relays are bad
Im4realg
09-21-15 10:11 PM
ChiefAllen
08-27-12 07:51 PM
