Misfire-Why?
Misfire-Why?
'99 ES 300, 200k miles. Riding down the interstate, the CHECK ENGINE and TRAC OFF lights come on, and the car starts running like crap. Pull over and reset the ECM. Purrs like a kitten for a couple of miles, then it happens again. Went by the mechanic to check the codes, and the rear cylinders, 2, 4 and 6, are misfiring. He says the coils on these may have fried, but I call BS because I can reset the ECM and they work for a while. Checked the plugs and wires, and they look fine. Would appreciate any suggestions on what to check. I'm a decent wrench, but not so good at diagnostics.
In fairness to your mechanic, when my car did the same thing, it would run decently if I reset the lights and then start crapping out a few minutes later. Replaced the coils, and no problems.
I have three good coils that I can sell you for pretty cheap, if you want to give those a try before you start replacing the expensive stuff.
could be bad coils or spark plugs....have you ever changed the plugs?
start with plugs if you havent changed those...always start with the most inexpensive items first.
Okay, tried replacing the coils; same problem. Took it to Toyota dealership for diagnosis. Was told the misfires were most likely due to VVTi sensor code that was showing up. Quoted approx. $500 to replace. NAPA shows camshaft sensor for $124.00 (P/N DEM SS10502). So, is this the part I need?
I've replaced the coil packs. Same problem. Took it dealer for diag. Said it was showing code for VVTi controller, and I should start there. I replaced the VVTi sensor (I'm assuming "controller" and "sensor" are the same). Same problem. So, does anyone have other suggestions? Is this the state of modern automotive diagnostics? Just throw parts at it until something works. If so, I think I could be a fairly profitable mechanic. I mean, seriously, this is what the dealership said would be their first step. So I would have paid $500 for a $100 part that didn't fix the problem? Obviously, I'm frustrated. Any help would be appreciated.
perpveloc
04-11-17 11:55 AM
elitegroup
10-02-13 04:12 AM
jcat_350
ES - 5th Gen (2007-2012)
11-16-12 11:25 AM
