Bulb Burnt out
I searched, but maybe not thoroughly enough, but i need to know how to remove the shift plate for a 2001 es300. All the letters 1-9 by the actual shifter no longer light up, and im sure its easy to replace, but just need to figure out how
Which part?
The part that lights up the gear selector??
If so, its easy, and all you need is your key.
You pry between the wood trim piece [it comes off as a whole] and pry in a few spots, its only like 4 clips holding it on.
Then you have to carefully slide it out from under the ashtray to get some working room.
Now where the bulb is, is a very tight squeeze, it took me about 5mins and much frustration to take the old one out and put my led in.
But it is a #74 bulb, like in the glove box and around the key ring. Same size.
GL. I don't have pics of this from my LED retrofit, but you can be rough and not worry. Mind you i also have a cluster with the seat heaters so you can pop those out to maneuver the wood trim a little more.
Just went out and removed it and got to the bulb in about 5 minutes as you said, if anything i was more worried about breaking anything Is it possible to get the bulb at an auto parts store? or do i need to go to lexus? i really dont care if its a green light like oem
