'93 4300K HID funny beam pattern
My right side looks normal with no cutoff, a little blurry from age. But the driver side has some prism action, I didn't do anything. Does anyone else have something similar?
![](https://hphotos-snc3.fbcdn.net/hs414.snc3/24979_379590397034_621582034_4369718_721041_n.jpg)
heres a ****ty video http://www.facebook.com/v/380553892034
Wow thats clean as hell, which HID did you use? Someone told me the bulb is out of alignment. Also, could overheating the lamp in the oven cause the projector to warp?
ES300 of course! I believe at the time I was using a MobileHID kit. Heating the bulb will NOT warp anything as long as you don't put the temperature too high or leave it in there for too long. I've had to do mine twice due to my turn signal flaking its orange coloring inside the housing
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
The problem was the actual bulb, it literally emitted red blue and white on different angles. That's what happens with cheap stuff. I put back my old 6K's that I bought locally and tweaked on the lens spacing to achieve a more even beam and better cutoff. Too bad its so blurry with the frosted lens, I am planning a retrofit sometime this year, most likely the mini H1.
![](https://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs326.ash1/28466_398988022034_621582034_4844502_2224437_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs316.snc3/28466_398988042034_621582034_4844506_7721048_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs130.snc4/36868_398989362034_621582034_4844557_6075191_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs150.snc4/36868_398989367034_621582034_4844558_7213535_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs130.snc4/36868_398989372034_621582034_4844559_5155629_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs150.snc4/36868_398989377034_621582034_4844560_6229343_n.jpg)
