Premium, middle grade or regular? (merged threads)
Old 01-19-06 | 01:38 PM
  #136
johhnyb's Avatar
johhnyb
I use this product in my ES and 87 works like magic if you reset the ECU. It take a few tanks but it stops the timeing from retarding and increased performance, burns cleaner and increases my gas mileage. 12oz =$12 so, 1oz/ 12gals.
www.polarmolecular.com
Old 09-13-07 | 09:00 PM
  #137
king-pin's Avatar
king-pin
Default es300 uses 87 or 91 octane?
hey. does the es300 run on 87 or 91? i have an sc and i plan on getting an es300. i noticed that on my friend's es300 gas gauge it says unleaded. i need to save money on gas.
Old 09-13-07 | 09:18 PM
  #138
Xterminate's Avatar
Xterminate
all lexus is recommended to run on 89 or higher octane gas I believe
Old 09-13-07 | 09:34 PM
  #139
Choas's Avatar
Choas
CL Folding 10,000
I prefer the 91 octane it runs better on it.
Old 09-13-07 | 09:39 PM
  #140
Xterminate's Avatar
Xterminate
if u have money sure use 91
Old 09-13-07 | 09:55 PM
  #141
Pheonix's Avatar
Pheonix
Cool
depends on the year. some 87 some 89+.
they'll all run perfectly happy on 87...
Old 08-05-09 | 02:49 PM
  #142
PDXLex's Avatar
PDXLex
Default Fuel Octane Rating for a 1997 ES300?!
I'm curious if it is really necessary to run premium fuel in a 1997 Lexus ES300? The owners manual states 87 Octane is adequate, but I have heard different opinions from several sources stating that the car requires 91 Octane Fuel...Is this really necessary, or am I just wasting my money on expensive gas?
Old 08-05-09 | 06:13 PM
  #143
Woogie's Avatar
Woogie
89 Octane is what I use. The difference between 87 and 89 or 91 and 89 is very minimal. Let's say the difference is 10 cents and let's assume you're getting 12-14 gallons per fill-up... you're spending only an additional 1.20-1.40 per fill-up.
Old 08-05-09 | 07:04 PM
  #144
ASG14's Avatar
ASG14
Only thing 91 will get you is a couple more hp. Only reason I use 93 in my car is I have to for the SuperCharger. I was using 87 before.
Old 08-05-09 | 07:15 PM
  #145
Lexusfreak's Avatar
Lexusfreak
Cool
Why not try running your ES for an entire month on premium.....document your findings & do the same on regular? Let us know.
I run my 05 ES 330 on regular.....Sunoco 87......I do not get any better or worse fuel economy than running Ultra 94......and my engine purrs like a kitten.
Old 08-05-09 | 08:39 PM
  #146
Bdub215's Avatar
Bdub215
the car doesnt require 91 but you wont be wasting your money on it. higher octane numbers burn slower = better
Old 08-05-09 | 11:44 PM
  #147
01LEXPL's Avatar
01LEXPL
Someone on a local forum [to me] did just this. Anyways findings show:
Both fuels = same thing. The difference is negligible. Although the driving style has a lot to do with. This test was done using typical/repeating driving habits.
I run it on 87. And if it happens to be cheap i'll pour in some 91/94 a few gallons or so. I never actually ran it on a full tank of premium.
Old 08-06-09 | 06:59 AM
  #148
Lexusfreak's Avatar
Lexusfreak
Cool
Yup I do the same thing when premium is cheap.
Hey 01LEXPL, where abouts in Ontario are you located? I'm quite interested in doing the LED's for my 05 ES 330.
Old 08-06-09 | 09:59 AM
  #149
285exp's Avatar
285exp
I would think that the Lexus owners manual would be the definitive source, and since they say that regular is ok then disregard the other sources. I have a 1997 ES300 that I have owned since new. I have run it on both, and found no measureable difference using premium, so I now use only regular.
You will be wasting your money unless there is a noticeable increase in either power or fuel economy, and there won't be.
Old 08-06-09 | 10:46 AM
  #150
01LEXPL's Avatar
01LEXPL
Nations' capital.
