Premium, middle grade or regular? (merged threads)
#152
I would think that the Lexus owners manual would be the definitive source, and since they say that regular is ok then disregard the other sources. I have a 1997 ES300 that I have owned since new. I have run it on both, and found no measureable difference using premium, so I now use only regular.
You will be wasting your money unless there is a noticeable increase in either power or fuel economy, and there won't be.
#154
I can't notice any difference in performance or idle quality. I have documented about 1 mpg better (.7 -1.2 mpg, not much but something) on 93 over an extended period more then once. Enough to make me think it's not a coincidence. I use 89 regularly though.
#155
Why not try running your ES for an entire month on premium.....document your findings & do the same on regular? Let us know.
I run my 05 ES 330 on regular.....Sunoco 87......I do not get any better or worse fuel economy than running Ultra 94......and my engine purrs like a kitten.
#156
#158
I run 91 in the summer or hot day - need slower burning gas, 87 in winter or cold day - no need to spend the money.
With 91, I got a little better gas mileage (about 1-2MPG more) and more power than 87.
No knock no ping with 87, 89 or 91.
#160
#161
#162
I know this is an age old question, but a search turns up 2 year old threads in this matter, so I thought a bump wouldn't hurt. Premium just hit $3 here, while middle grade's hovering in at $2.93 and regular ten cents cheaper at $2.83. I'm not cheap, and I fully appreciate the rationale that a dollar or two extra can help in the long run, but I'm curious if it's really necessary to put in premium. Please correct me if I'm wrong, but the engine in my '01 is the same as was in the Camry, and I'm sure Camry owners were told to use regular, therefore is it sound logic to say I can use regular? I guess I'm looking for two answers here:
- Subjective (Qualitative observations running premium vs. middle vs. regular) = Do you notice a difference in performance, engine noise, clunking, rpm's etc?
- Objective (Quantitative observations) = MPG and actual mechanical info that states a direct requirement for one grade of fuel over the other
Thank you very much for your time
