Premium, middle grade or regular? (merged threads)
Old 01-14-12, 01:37 PM
  #211
imherenow
imherenow's Avatar
89 for me as well
Old 01-14-12, 02:52 PM
  #212
ASG14
ASG14's Avatar
93, because I can't use anything lower with my engine modification.
Old 01-14-12, 03:18 PM
  #213
EEngineer
EEngineer's Avatar
94 cuz i'm supacharged
Old 01-14-12, 03:27 PM
  #214
ASG14
ASG14's Avatar
^ Screw off. We don;t have 94 here or you know I'd be using it, haha.
Old 01-14-12, 03:59 PM
  #215
jbl-1985
jbl-1985's Avatar
The 2000 as per the manual says minimum 87, and that's what I use. I put in 93 a few times and I really did not see any difference.
Old 01-14-12, 06:02 PM
  #216
duly
duly's Avatar
Thanks for the response.
Old 01-14-12, 07:37 PM
  #217
Timothyj
Timothyj's Avatar
I use 89 in my 04 ES. Tried mixing 87, 93, 87, 89 etc. Just runs better with 89. I run Mobil or BP.
Old 01-15-12, 09:01 AM
  #218
hypervish
hypervish's Avatar
I use 93 in my RX300 which has the same engine as the ES300. I'll be running 93 octane in the ES300 once I get one as well.
Old 01-15-12, 11:39 AM
  #219
yeldogt
yeldogt's Avatar
All of ours have always used 87 - you get no benefit from using higher octane than the engine can use -- these are not high compression engines.
Use a name brand gas withe detergents -- and you are good to go.
Old 01-15-12, 11:58 AM
  #220
hypervish
hypervish's Avatar
The 1MZ-FE engine is high compression at 10:5:1.
I personally, see better throttle response, and it runs better on 93. Not to mention, I get better mpg on 93. It's worth it to me.
Old 01-15-12, 12:56 PM
  #221
ASG14
ASG14's Avatar
To add to the poster abover, the owners manual racommends using 91, butr says 87 is also fine to use. You WILL gail a few whp on 93 over 87, but not enough to really make a difference.
Old 01-15-12, 03:34 PM
  #222
RXGS
RXGS's Avatar
89, but whenever i run 93, i get worse gas mileage
Old 01-16-12, 09:43 AM
  #223
Rollin'ES3
Rollin'ES3's Avatar
91 Premium when I had my ES300 (2000)
I miss that cars MPG and how low key it was.
Old 01-18-12, 06:31 PM
  #224
worldforgo
worldforgo's Avatar
In the summer my local gas station offers ethanol free 91, so I do that. Otherwise, 89.
Old 01-19-12, 02:08 AM
  #225
dewso1
dewso1's Avatar
least we get here in aussie is 92 with up to 10% eth,
otherwise if i have a bit of money i go for 95 or 98, but usually the 92.
Quick Reply: Premium, middle grade or regular? (merged threads)
