remote Turn On Wire From Radio
I have a 2000 ES300 Platinum with the Nakamichi stereo. I'm going to add my sub and amp to the stock system and remove the stock sub from the rear deck.
I've got a few questions:
1) After I remove the AC trim above the stock radio how do I finish removing the radio? Do I just remove the two bolts that have become visible and lift the whole radio/trim assembly up to gain access to the back of the radio?
2) Can anyone tell me which wire from the back of the radio is the remote turn on/off for the stock amp? (I'll splice the remote on/off wire for my aftermarket amp into this wire.)
3) Where is the stock amp and how do I gain access to it?
4) Any thoughts on the best place in the trunk to run a 4 gauge ground wire to?
Thanks for any help...Martin
P.S. The link in the DIY section doesn't work.
2.) I ran mine to the fuse box, but I forgot which fuse. Basically anything that turns on when the car is started.
3.) Stock amp in a 2000 is behind the glove box. You must removethe glove box to gain access to it.
4.) I drilled a hole behind the carpeting in the trunk. On the drivers side, pull down the carpeting, nothing but metal. Pick a spot, drill a tiny hole, get a screw, wrap it around and screw it in.
GL
2). I can't remember which one it was. you will have to dig in the forums for the diagram. You can also just tap into the wire and test it if needed.
3). The stock amp is located behind the glove box. You have to remove the entire glove box to gain access to it.
4). I had to take out my back seat and ran it right through where the compartment opens. There should be the corners where you can run the power wire.
did u ever find it?
there are some remote turn on adapters that you can buy/use. their pretty cheap too. i had one installed in my car when i got my first sub/amp combo in my gs. it turned the amp on/off with radio. it basically used the signal from the speaker wires to turn on and off.
west709
04-05-12 12:33 AM
imjohnphan
12-11-07 04:14 PM
