02 es 300 key
02 es 300 key
HI, new guy here, a couple of questions.
1- I just bought 02 es 300; It come with only 1 key (platinum edition). Where can I get the key with remote beside Lexus dealer?
2- I locked the car and some one was trying to open the door on passenger’s side and set alarm off. Since that day, Passengers side either window or door are not working, when I got the car both were working, I still unlack the door from driver side but I can not the window. do I need to reset or.....?
Thanks
Thanks
1. Locksmiths can make a key, but it won't be a Lexus-logoed key. But even after it is cut to an exact match for yout car, the key still has to be programmed to your car. That is done starting with the key you already have. Then there is a series of steps such as opening and closing the drivers door, and steeping on the brake pedal a certain number of times, etc.
http://www.locksmithcharley.com/toyo...structions.pdf
See section B.
2. I don't know about that.
See section B.
elvenrider
02-02-18 02:14 PM
