Keyless Entry Problem
The keyless entry does not work on a recently purchased a ‘94 ES300. Replaced the battery in both keys. The car's security feature is functioning.
The dealer's tech looked at the problem and apparently verified it wasn't a ‘user problem’.
The dealer suggested either:
- repairing the problem (most likely the electronic control module $1100) or
- installing an after-market keyless entry system ($199).
I am really bummed out as they lead me to believe it was just the battery in the keys when I bought it.
Does anyone has experience with this?
Thanks
Thanks
This is just my humble oppinion, but I'm not a big advocate of the Lexus Keyless entry system.
As cool and prestigious as it is having the button built into the key, I simply prefer to have a seperate remote entry module, since you can do so much more.
I personally cannot tell with one button (94 still has just one unlock/lock button right?) whether I have locked the doors or not, with no noise confirmation or such to tell me.
A seperate aftermarket keyless entry system can let you pop the trunk, lock/unlock and some even let you roll up/unroll windows...
I know you probably weren't going to spend $1000 versus $100, but just don't think twice about it, you'd be doing the right thing anyway
I'll probably get mine replaced in a few months.
I'd just go for an aftermarket security/convenience system as well. I've got a Clifford Arrow 3 on mine, fairly basic security and keyless entry with trunk pop from the remote for $300 installed. I'd recommend the Clifford line, whichever one fits your needs; they are one of if not the most highly regarded companies in the security business.
im thinking about using my factory system to do things, there is a guy around here that can make my remote unlock on my key flash headlights, roll up windows, do everything, but without having to buy a new security system
Originally posted by TheBigGuyRy
Is it a viable option to install one of these systems at home, or would you all just reccomend taking it in to a shop? How much would installation be, in that case?
As for cost, I think the install on mine cost as much as the hardware, it can often take the better part of a day to do a security system. I had to leave my car from 9 AM to 6 PM and I think he spent most of that time on my car.
Originally posted by EGainer
yeah, you did make sure that the reciever in the car was turned on right? go for the aftermarket then.
Any other simple checks before going for an aftermarket solution?
Thanks
ok, i was getting ready to tell you how to turn it on, but the ability to turn it on and off didnt come until the 95 model. so, do your locks work from the inside when you try to lock all the doors with the button?
big guy, yes i know what you mean about not knowing if the doors are locked or not, that was one thing i was glad that got changed when i went from my 93 to my 94 model. 93 and below have no audible sound for the locking. but you know that you can go to somewhere and have them wire your horn to honk or lights to flash when you use your key to lock the doors. they can wire it into your factory system
I guess I could get a quote on this when I go to the stereo/alarm place to have that electrochromic mirror job quoted (whenever the part chooses to show up).
I don't know what is involved, but I'm sure I can get the dome light to come on with it. Lights Flash, Dome light on/ all interior lights come on. that would be a cool setup, oh yeah, and the trunk to open
