Help! Cluster LED upgrade
So i decided to upgrade the back lighting with the 74-W from superbrightled.com I replaced all 8 bulbs.
Issue is in the day time there is SEVERE spotting but at night time it is perfect. Im almost tempted to put the stock bulbs back in.
What did i do wrong?
Do i need to get brighter leds?
__
95' ES300
__
95' ES300
LEDs are directional. You need to add multiple LEDs all around to make it even. Try looking for bright LED strips and soldering the strips into place for the best light output in the cluster. Its a bit of a DIY but its possible to make something that used to be sold here on the forums by OLT in the past
LEDs are directional. You need to add multiple LEDs all around to make it even. Try looking for bright LED strips and soldering the strips into place for the best light output in the cluster. Its a bit of a DIY but its possible to make something that used to be sold here on the forums by OLT in the past ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I did the same 'mod' in my gear selector. It shines more in the middle of it, than the rest of the letters...
You can't avoid hot spots on single led's
something like this is more uniform, but also more work:
![](http://utilitiesupply.com/images/Flexible-LED-Strips-SLP12-12-.jpg)
hmmm I found this http://www.superbrightleds.com/cgi-b.../specs/FLS.htm
Looks like i can cut in to 3led strips. So, what i was thinking was per bulb socket have a led strip of 3. Since it runs off 12 volt nothing i have to do except remove cluster and connect each section to each bulb socket.
Also, arent there LEDs that are omni-directional? more like bulbs? I too have the same issue on my SC300 cluster, ill post up pics, at night its awesome and super bright but during the day it has the aforementioned spotting.
I know its due to the bulb ( led ) design so im trying to get used to it, but it is rather annoying.
Cashflo
07-26-12 09:20 PM
