3ES Wood Shift Knob
Anyone aware if there's a matching dark woodgrain shift **** for a 97-01 ES? I'm guessing it'd need the shift button on the left and overdrive button. The 1st Gen RX woodgrain shift **** looks promising.
I had an aftermarket wood grain shift know, similar to an OBX shift ****, but the center button broke off and could not find a replacement. It was wood grain and chrome. Now I have a carbon fiber and chrome OBX shifter, but its also made of plastic, but is holding up better then the first one I had.
Woodgrain + Grey leather is what I'm looking for.
EDIT: Here's the RX300 shift ****. Looks almost like a wood version of the stock one,
cgi.ebay.com/ebaymotors/LEXUS-RX300-WOOD-SHIFT-****-SHIFTER-UPGRADE-99-00-01-03-/170502346862?cmd=ViewItem
I dunno, that's exactly what I've been looking into. It definately looks like it could fit in our ES's. Some guys were discussing it here years ago,
us.lexusownersclub.com/forums/lofiversion/index.php/t13732.html
I believe it was the years 2001-2003 that had the woodgrain shift ****. Would look fantastic in our cars no doubt.
![](http://images.autotrader.com/scaler/565/421/images/2010/5/21/280/075/16079884326.280075473.IM1.16.565x421_A.562x421.jpg)
Found a woodgrain RX300 shift assembly. We took it apart to get at the ****, and it's different than the ES's **** but similar too. Too late now but tomorrow I'll know if it can be done.
![](http://img821.imageshack.us/img821/1819/cid201007212335.jpg)
![](http://img801.imageshack.us/img801/2619/cid201007212341.jpg)
Got it in there. Basically I needed to drill a hole in the base of the new **** because the original mounting holes are on the back (for the RX300 shift assembly) whereas on the ES the mounting are one the front. It was difficult finding the exact spot to drill the hole because it has to be exact, i.e. if it is too high up the shift button won't engage the shift rod and if it's too low it will always be like the shift rod is being pushed down preventing you from removing the key from the ignition when the car's in park. So it took a few trys but I seem to have got it. It still gets stuck occasionally but jiggling the **** seems to fix it, time will tell. The O/D wires I cut off and spliced together, and I had to make sure the wire fit into the little clip-in holder on the shift assembly so it wouldn't get stuck in the shift assemblys bolt at the base. The ES's stock grey plastic cover will fit underneath the RX's **** but I needed to trim down the little groove on the inside back, then it will lock in place. I was only able to get one screw in to hold the **** so it's slightly wobblier than the stock ****, but it is firmly in place.
The woodgrain isn't an exact match, but it's pretty close. It matches better than it appears in the pictures below, and shift ***** wear from use so I think it matches fine. Overall it took 3-4 hours but I attribute most of that time to matching up the hole in the **** to the hole on the ES's shift assembly so it would function. Unfortunately I can't give the exact location of where to drill the hole, but it's close to being directly opposite the original hole on the back of the RX ****. I tried tape attached to the shift assemblies mounting rail and I marked off the hole and created a notch right where the bottom of the **** was (see picture), I'm sure there must be a better method though.
![](http://img641.imageshack.us/img641/7793/2010072295115801.jpg)
![](http://img138.imageshack.us/img138/4143/2010072295125025.jpg)
![](http://img33.imageshack.us/img33/4213/2010072295140333.jpg)
![](http://img534.imageshack.us/img534/7152/img0726dh.jpg)
![](http://img534.imageshack.us/img534/675/img0728wd.jpg)
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
IMO. Except from the 3 different color woods, it looks great.
Great job and glad you have that much love towards your Lexus to do such an upgrade.
Thanks for the compliments. Look for 2001-2003. It seems in 2001 the wood shifter was introduced, but it also seems that the leather shifter was also available, so make sure to request pictures when ordering. I recommend browsing car-part.com, there are some decently priced assemblies on there.
Browsing autotrader and I noticed the LX had a woodgrain shift ****. I can't really tell if it's different from the RX's but maybe the shift **** off the 2000's LX is slightly different and would be an easier fit,
![](http://images.autotrader.com/scaler/565/421/images/2010/7/1/281/185/16537115689.281185695.IM1.08.565x421_A.565x377.jpg)
Uggghhhhh, decisions now, lol. Hmmmmm, didnt realize the LX had an inline shifter too. I wonder which shift **** is close in size to the ES. I have found several RX300 shifter assemblies and just a **** by itself, wood and leather, but different shades on the leather, priced from 50.00 bidding to 245.00. Now I dont know what to do, LX or RX?
