1995 ES 300 starter replacement
Old 06-10-10, 10:31 AM
fice0140
fice0140's Avatar
Cool 1995 ES 300 starter replacement
Hi,
I need to replace my starter in my 1995 ES 300. It looks like it may be pretty easy. Is there anything that i should be aware of? It looks like 2 10MM bolts are holding the starter in. Again any suggestions and or tips would be greatly appreciated before i give it a shot.
Thank you,
Old 06-10-10, 10:42 AM
JSM1284
JSM1284's Avatar
Disconnect battery ground cable and disable airbag system as described under Technician Safety Information.
Remove battery.
Remove cruise control actuator as follows:
Remove actuator cover.
Disconnect actuator connector.
Remove three bolts and cruise control actuator.
Remove starter as follows:
Disconnect starter connector.
Remove starter wire nut, then disconnect starter wire.
Remove two starter bolts and starter.
Reverse procedure to install
Old 06-11-10, 07:41 PM
S8KWR
S8KWR's Avatar
www.camrystuff.com Go to 3rd generation. Look through the manual, they should have a step by step with pictures. its PDF.
Old 12-03-16, 08:24 PM
JCC511
JCC511's Avatar
Remove battery.
Just completed the starter swap on my '95 ES 300. I also had to remove the bracket that the cruise control actuator mounts onto which is also the same bracket that the battery sits on. I ended up having to pop some of the tubes off to make space to get the old starter off and the replacement in. I thought I was going to have to remove the airbox, but it was not really in the way. I am going to try to post some pictures. I should have maybe made a video.
Battery removed and ready for next steps.
Bolt toward the front of the car and clip to pop out of cruise control actuator cover for removal.
Cruise control actuator cover removed.
Cruise control actuator removed.
Old 12-05-16, 05:04 AM
jaredmac11
jaredmac11's Avatar
One piece of advice, pay to have your starter rebuilt. It will be cheaper than the lowest cost new starter. New starters are JUNK unless you pay.
All they do is take your old one, refurbish it, and sell it for more.
Toyota OEM starters are gems. Unless you already have a Auto Zone, Napa, whatever piece of crap in there then do what you wanna do.
Old 12-05-16, 10:31 AM
JCC511
JCC511's Avatar
The replacement I installed is a remanufactured from NAPA with a three year warranty and I have to return the OEM to get the core charge back.
Old 12-05-16, 10:43 AM
jaredmac11
jaredmac11's Avatar
Right. They just send those off out of the country to get them rebuilt and then they sell em back. Id prefer to keep the OEM one with better parts. When your starter goes, its all parts that just wear out (brushes, etc) and you get to keep the good internals. Im just speaking as someone who knows someone in the business and has told me always keep the Lexus/Toyota OEM starters. He says they are quality.
Old 12-05-16, 10:57 AM
JCC511
JCC511's Avatar
I agree. I just did not have time to send it off for rebuilding.
Old 12-05-16, 11:04 AM
jaredmac11
jaredmac11's Avatar
I hear that.. and it's a dilemma. My guy will rebuild starters quickly, but thats still about 2 business days. If you dont have a backup car, your options are very limited.
TriniLex
RX - 3rd Gen (2010-2015)
05-08-18 10:28 AM
Cybernetic
04-10-12 01:12 PM
attis
Performance & Maintenance
06-12-09 06:52 PM
CyberSC4
CL of Southern California
03-18-06 06:47 PM
dundfaukus
GS - 1st Gen (1993-1997)
11-05-04 04:28 PM
Quick Reply: 1995 ES 300 starter replacement
