I need the A/C experts again
This was a old issue but i'll ask again......Ok i start the car, turn on the Ac.....it works for about 20 seconds and then the dase lights go out and the 10amp fuse is blows. If i unplug the clutch harness and change the fuse the lights come back on.
If i add a new or seperate ground connection on new or seperate power supply to the harness will this solve the problem?
Im guessing its a bad ground or something.
thanks
thanks
I would check for a short in the harness.That is why the fuse blows.Also, could be a overload to A/C. Checking the ground is always a good thing, but a bad ground would not blow the fuse, a short would.
