Spring Clip
Old 06-29-02, 09:04 PM
Kyle Harty
Kyle Harty's Avatar
I wouldn't put them on my car, I tend to take mezoom's point of view. I suppose it might be an option for a car that's really not worth doing much with, but you're driving a Lexus, treat it well and like the classy car it is.
Also, if you don't clamp all 4 springs exactly the same, you can end up with problems from the suspension being uneven. That's the same reason I wouldn't heat and compress or cut springs. Also, when you do either of those, you're changing the springs from the way they were originally designed and this can have undesired side effects.
IMHO, just shell out the cash for some springs that are designed for the car. I've got B&G's on mine, $250 for the set and I'm very happy with them.
Also, if you're lowering the car, you should upgrade the struts as well. A lowered car puts more stress on the struts and the stock ones won't last too long.
Old 06-30-02, 08:40 AM
Lexpusher96
Lexpusher96's Avatar
I've been lowering cars and trucks for over 10 years now and have used almost every method available. The clamps and heating methods are what we used to do about 10 years ago when we couldn't afford the proper ways. It has been my experience that the spring clamps will not hurt anything. They are removable and the spring rates are unchanged. The heating method is the worst method, however. When you heat metal, it weakens it. Therefore, you have changed the spring rate of a spring you have heated. Plus over time, the springs will sag or compress more than desired and will have to be replaced. Once you have heated them, you have ruined them. The best way to go is with new drop springs and shocks. But the clamps will be ok if that's what you want to do.
Old 07-01-02, 09:12 AM
EGainer
EGainer's Avatar
thanks for straightening us out lexpusher
Old 07-02-02, 01:29 PM
cialz
cialz's Avatar
to who ever said its not a honda...
we drive toyotas...
so wats your point....
es300 just a camry with more luxury...
Old 07-02-02, 02:30 PM
j2tha0e
j2tha0e's Avatar
Talking es300 just a camry with more luxury
no comment
Old 07-03-02, 06:53 AM
EGainer
EGainer's Avatar
the es is not a camry with more luxury, if you are going to refer to it as toyota, try windom
Old 07-03-02, 10:10 AM
cialz
cialz's Avatar
oh its not?
hmm lets see... same frame... same engine... same trans...same suspension.. even door clips have same part number...
i know its a little different but it is just basically a toyota... yea i know bout the windom... its just like the tl and accord.. same platform and stuff... but at least tl has different engines...
Old 07-03-02, 10:19 AM
EGainer
EGainer's Avatar
we've had this argument in CL before. you can think what you want to and i will myself. end of that
Old 07-03-02, 10:23 AM
meZoom!
Super Moderator
meZoom!'s Avatar
Originally posted by cialz
oh its not?
ok, IMO if they were that similar, toyota would have never come out with both the camry(gracia) and windom in japan. they have distinct differences.
Old 07-03-02, 10:27 AM
EGainer
EGainer's Avatar
I agree with MeZoom
Old 07-03-02, 01:29 PM
cialz
cialz's Avatar
i know there is a difference thats y i dont drive a camry.. but that statement thats its not a honda is a bunch of bs
richylee
Suspension and Brakes
01-04-13 10:12 PM
minnyminh
05-23-09 07:07 PM
OOM
03-19-08 04:13 PM
CK1_RX3
RX - 1st Gen (1999-2003)
10-03-02 08:30 PM
EGainer
08-07-02 08:18 AM
Quick Reply: Spring Clip
