i cut a small hole in the steering boot. where the steering column goes through. try that.
i will look into it. thats the first one i saw, but i thought it was too much of a major part to do surgery on it. lol but il definitely check it out again.
drilling isn't a big deal. But make damn sure you use grommets if you do. Otherwise, vibrations over time grinding away at that shielding could put your friend in a world of heart.
i drilled where the green wire is that goes to the engine. cut the wire, drilled, ran power, threaded green wire back through, spliced, done. and it was easier because the hole was already there. right infront of the driver. i can take pictures. but trust me, wouldn't do it any other way. imo
yeah if you can just take a quick pic or two for me. it doesnt have to be too detailed, just a quick pic through the engine bay or through the drivers footwell would be great. which ever is easier for you. thanks a lot.
i think this would help a few people out in the future, i did a search on this, and there was a few of the same question, but with no "real" solutions, just a suggestion or two, but nothing too helpful
i remember i had the exact same problem, and got no answers. I asked the same thing and was stumped. hopefully it WILL help out future installers:
here is the wire i spliced and crimped from the motor:
Actual hole:
Actual hole:
great pics man!!! thanks!!! these DEFINITELY helped! i did look at the footwells and i saw that the cut out was kind of there for the hole. but i wasnt too sure... thought id get a second opinon first. and i was trying to go a difff way so i wouldnt have to drill. but yeah, definitely the easiest way!! did you drill through the engine gay or through the footwell?
..im thinking footwell since the engine bay is at an awkward angle?
or you could just doorjamb it like me. Ghetto? yes, but it works.
lol im not sure what you mean by door jam it... i think i know what you mean.. but i dont think i can door jam 0 gauge through there lol. door wouldnt shut.
engine bay, footwell was suck an akward angle, but so was the engine bay, but it worked just fine. it is literally impossible to do the footwell.
really? i dont remember what angles each one is at, but i wouldve thought footwell would be easier. il check both out, but if engine bay worked for you, then im sure it should too.
