Attn: Lexus experts - ES 300 Radio Compatibility
Do you absolutely, positively know for sure if a 2000 or 2001 ES300 wood-faced Pioneer radio will fit a 1997 ES?
Thanks - J
Thanks - J
I don't want to install an aftermarket radio; I want to install a Lexus, model year 00-01, ES300 factory radio - (they have a wooden faceplate) - into a 97 ES300. My concern is whether or not the connector plugs on the radios are the same (both radios are made by Pioneer).
A representative of my local Lexus parts dept. said it would not work, however, he also said that no radios in an ES, of any year, came with a factory radio with a wooden faceplate. He seems to think that all wooden faceplates are aftermarket kits.
I disagree because all the radios I have seen on the 00-01 model years have the labeling printed on the wood faceplate itself, whereas the aftermarket kits are cut out around the labeling.
Because the parts guy is oblivious to the fact that 00-01 models factory radio DID come with a wooden faceplate, I question his opinion as to whether on not they are interchangeable.
So… I would like a second opinion as to whether or not a 00-01 model year Lexus ES300 radio is compatible with the wiring harness of a 97 ES?
Thanks again - J
Thanks again - J
Was this wood faceplate found on special edition ES's (i.e. Platinum Series and Coach Edition)? I've been in an non-Platinum '01, and it has the same black plastic as my '96. The aftermarket wood kits do have cutouts for the labeling. That allows the backlighting to show through at night. An all wood faceplate, if it's as you describe, would need transparent plastic inlays to allow the light to shine through, otherwise, things would be confusing at night.
no man, lexus does not come with wooden faceplates, nto even on upgrades. i've seen it on some cars, it was aftermarket and looks ugly. even my dads ultra LS43 doesnt have wood
Here is a pic of a typical 97-99 faceplate. Notice the location of the pre-printed "compact disc" labeling (on 00-01 models it is in a different location and printed directly on the wood).
Here is a pic of a typical 00-01 faceplate. Notice the labeling is printed on the wood itself and the LED lights are integrated into the wood (instead being cut around). It should also be noted that the wood part of the faceplate is flush with the plastic areas (instead of being raised, as is the case with aftermarket kits).
Here is a typical aftermarket wooden faceplate kit. Notice there is no printing on the wood (I couldn't find an actual photo of the faceplate but trust me, there is no printing). Also notice the cutouts aroung the labeling.
So, I think these pictures prove that the 00-01 model year Lexus came from the factory with wooden faceplates.
Having said that, Does anybody know for sure whether or not the 00-01 radio (and a/c controller), plugs are compatible with a 1997 model?
Thanks again - J
Thanks again - J
I'm willing to bet that these people don't even own these cars anymore, since the thread is about 11 years old! But I can tell you that the 2000 has different connectors than the 97, if that helps...
I just bought a wood face Pioneer off eBay that was billed as a '97 which is what I need but like Jazzer pointed out the plugs are different so no, it did not work.
I am still looking for a fully functional '97 Pioneer but not willing to buy the other eBay unit listed for $375. Ouch!
Mystro
09-06-06 09:28 AM
