Car trouble
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
I have a 92 es300 and i cant pass my emissions test due to high hydrocarbon and carbon monoxide levels.. I decarbonized the engine repaired the converter fixed all leaks and i still fell the emissions test i actually fell the test four times and i cant get plates for my car. Have anyone else had this problem if so can u help me out so i can fix my problem please......
How many miles are on the motor? Have you ran a compression check? Do you have the original O2 sensors, or have they been replaced? Another possibility is a leaky injector, have you tried injector cleaner?
Im not to familiar with the 1992 ES300, but wouldnt there be a CEL if the emissions is bad or this pre OBDII? I had an issue with my 91 Nissan Sentra, not passing smog in Calif. and was told to replace the Cat. Converter, which I did and I passed smog. I was told if your car runs rich over a period of time, you can burn out your Cat., then you'll have passing smog issues. Good Luck.
Enigmatic1
08-21-18 04:58 AM
AntzCro
15
08-25-16 01:18 AM
firsttimer
26
01-07-14 02:00 PM
