1992 ES 300 Timing Belt Tension
Hello, I have just finished replacing the water pump on my 1992 ES 300. and now I really can't figure out how I can put the timing belt back on (new one). It is just so tight and I haven't been able to figure out how any of the tensioners work. Any suggestions??
If you have a hydraulic tensioner(like my 95 does) then you have to take it off, put the belt on, and then put tensioner back on. the tensioner looks like this... ![](http://www.partsgeek.com/assets/rep/thumb/7534-01036674-1025346.jpg)
Just make sure if you pull it off that you have a C clamp to put the pin back in.
