92 es 300 need help
If I spray starting fluid in it then it starts and stays running. But when I turn it off its dead again, The plug wires were arcing all over the engine so I replaced them but now i have now idea. Can anyone help???
Check your coolant temp sensor, (this is NOT the same as the water temp gauge in the dash, the engine computer uses it's own temp sensor). Make sure that you are checking the correct sensor. There are three coolant sensors. one for the dash guage, one for the ecm, and another for the cooling fans.
