System in a 2002 ES
System in a 2002 ES
I just got a black 2002 ES300 and i wanna put a system in it. How in the hell do I hook up the amp to the stock radio. Do i need a line level converter? If so what do i hook that up to? Please Help!
Chicago Lexus Club Moderator
Line Out converter.
All you need is a GOOd line out converter. You can get them at any car audio place, and you should pay around 30-45$ for a good one. All you have to do is connect some of the wires coming out of the unit into the speaker wires of your rear speakers. Splice it in i mean, then it forms them into a rca signal. If you want a four channel amp, they have different l.o.c.s that will have multiple rca outs. The biggest problem will be runing the power wire through the fire wall. You will also have to find a place to run a remote turn on also, but that shouldnt be to bad, you can also just make a switch instead of running the wire to the back of the deck so you can turn off the amps whenever you want. Let me know if you have any qustions.
Adam " Lexist "
Adam " Lexist "
