95 es300 center brake light
Anyone know how to remove the center brake light assy? What's i've found simply says to pull it forward. That seems to be a little trickier than it sounds. I can't get it loose from the back deck. I'm thinking there's a trick to it.
Lexucanafer
I used something with a 90 degree hook on the end (like a coat hanger) to pry under the corners of the plastic brake light housing and pull it forward - first on one side and then the other until the housing came loose.
