trunk release via, dash\or fob works sometimes
I can hear the relay in the front dash when I push the dash button or the key FOB, but the truck does not open have to use the key, then after some time passes it starts to work , both the dash and fob button. Check the button in the glove box and it is in the normal position.
Not sure if the relay is going bad or the solenoid in the trunk is on its way out.
Any ideas?
Any ideas?
