High pressure p/s hose
Ok, so I am new to the forums, and I just purchased my first Lexus ever. I have driven Toyotas my entire life but moved on up and purchased a 96 ES300 a month ago. Well, I have a leaking High pressure p/s hose that has all but burst and is leaking about half of my reservoir a day on a hot day. I am sure this has been asked in the past but does anyone have a breakdown on the easiest way to replace this wonderful hose?? I appreciate all of you and I hope you are as friendly as the Supraforum people when it comes to helping fellow owners. Thanks in advance.
Nick
Nick
I have the same problem. I just removed the intake manifold to take a look at my spark plugs and still couldn't see where the pressure hose was. I don't even know if that's actually my problem either.
Help us.
Help us.
I got the hose off, just need $515 for the part from Lexus... what a joke.. You dont need to take the manifold off... just have to do some creative twisting and turning.
Look in the local yellow pages, there are shops that speciallize in repairing hydraullic hoses. If the metallic hose ends are in good shape, all they need to do is cut the crimps off and replace the rubber hoses and crimps. You can save major scratch this way.
Yeah, they're pretty expensive. Had a customer (body shop) that took it to a place that specializes in hydraulic hoses and charged him $48 to replace the rubber part of the hose.
It might be cheaper, If you call toyota and ask them.The part should be the same from 94-96 v6 camry. if not go to your local junk yard and try finding a hose thats in good condition.It shouldn't pass a $100. www.rockauto.com can also be a cheaper solution.
just an update... I had the guys down at driftmotion make me a custom high pressure hose for $90 out the door. If you have your old hose, they will need you to send it to them, so they can use the fittings for the banjo and the power steering pump for the new hose. Love it. Install this weekend so I will let you know how it goes. Pics are of the old hose I took out, and the new custom hose that was made.
I just had that hose replaced on my 1997 es300 because it was leaking. the leak has stopped since it has been replaced, but now it makes the groaning noise it usually makes when it was leaking and low on power steering oil. The power steering oil reservoir has enough oil. what could the problem be? bad hose or was it installation problem? the hose I got it from rockauto.com. It was installed by a mechanic not myself. Thank you.
NWhere is the wheel lock located? Do I need tools to turn it to lock? Also can I do it my self while the engine is running? Sorry I don't know much when it comes to what's under the hood.
Wheel lock is the end of travel, Basically you are slowly turning the wheel from right to left. Stoping when the wheel comes to the hard stop. You can do it yourself, but it helps if you can see the bubbles in the reservoir. It takes awhile to get all the air out of the system.
Does it appear to be improving on it's own? It should with normal driving.
You have to go from right stop, to left stop in order to get all the air out. Having a second person to assist you will allow you to see how many bubbles are still there. I assume that you have checked the belt for correct tightness.
I had the chance to take it back to the mechanic. There are no bubbles. The mechanic said that its the steering wheel pump and it needs to be replaced.
My question is when the high pressure was leaking the noise was only there when the oil was low and went away after I refilled. Now I don't have the leak but the noise is there. How is that possible?
I also looked at rock auto and saw that there are multiple steering wheel pumps. Any recommendations? They also say without resvouir, what is that mean?
