2000 ES300 Platinum CEL and TRAC Light issue
Hi Every one, I have a very interesting problem on my hand. MY ES300 recently popped up with TRAC and CEL Light. I took it to my Mechanic and 3 Codes came on reader. P1130 twice and P1135. Mechanic changed the MAF Sensor and also Bank 1 Sensor 1 Air Fuel sensor. We reset the light and I took off. Light came back on after a few miles but this time we only have 2
P1130 codes. We looked into details and this is what the reader showed
Fuel System 1 Fault
Fuel system 2 nothing here
STFT Bank 1 -20.3%
LTFT Bank 1 47.6%
STFT Bank 2 1.5%
LTFT Bank 2 -1.5%
RPM 843
Intake Air Temp 113 F
Any Help will be appreciated
Fuel System 1 Fault
STFT Bank 1 -20.3%
LTFT Bank 1 47.6%
STFT Bank 2 1.5%
LTFT Bank 2 -1.5%
RPM 843
Have you visually checked the condition of the hoses? Has any work been done to the engine in the past several months prior to the light comming on? I would also check for leaks. Does your scanner give you updated trim numbers? If so you can easily use a UN-lite propane torch to check for leaks in the intake. With a low flow of propane, when the flow is pulled into a leak, the short term trim should change. You will probably also hear a change in idle.
