ES300 Original Keys
ES300 Original Keys
I read most of the threads here about the original 2001 ES300 Keys but am somewhat confused.
When I bought the car used 10 months ago, I received two original Lexus transponder keys. One of the keys includes a three button remote, and the other key does not include the remote buttons but is still a transponder key.
So my questions are as follows:
1) If I loose my 3 button Lexus remote key, can I get a duplicate 3 button Lexus transponder key from the dealer, without him having to change my ECU. This assuming that I still have my Non-Remote transponder key in my possession.
2) How much would it cost to get another remote transponder key cost from the dealer. (Including cutting and programming)
3) Would it be cheaper to order a spare 3 button Remote transponder key NOW as long as I still have my working Remote transponder key in my possession
4) Is my Non remote transponder key refereed to as the Valet key?
5) Does anyone know what type of keys, and how many originally came with this car?
Thanks
Phillip
Thanks
Phillip
Thanks
Phillip
Thanks
Phillip
1). Cannot program a master key with a valet key. You must have a master key on hand.
2). Key with transponder alone is around 150.
3). Yes - however, this will do you no good if the max number of keys have been programmed.
4). Yes. Valet key opens the car and starts the car with no access to the glove box or trunk.
5). Not sure on this one, but I think it's the max number of keys the ECM can be programmed with.
The below page is saying that for 2002 years and later, you can delete keys:
http://www.locksmithcharley.com/toyo...structions.pdf
Scroll 2/3 down the first page where it says how to "Delete all keys other than present master key"
imjohnphan
12-15-06 07:53 PM
2000, 300, auto, car, es, es300, key, keys, lexus, master, programmed, programming, replacement, set, transponder, valet
