P0136 Check engine code!
i know its the 2nd o2 sensor on bank 1, but is an easy fix? if you clear the code would it do anything?
any pics where the sensor is?
thanx in advance
thanx in advance
Hey if you clear the code a different one might come up i useally clear them a couple times b/c sometimes different ones come up and they try to get you all confused but in general all o2 sensors are easy. Did you do a search on the fourm first sure alot of ppl already asked same thing and should pin point the prob little better.
