Are there 2 o-rings on the 93 es300 3vzfe distributor?
Some idiot mechanic or PO turned one of the distributor cap bolts in so hard that it's sheared off, and 3 of the ears on the cap are cracked or broken. I have a new cap and rotor in hand. However, even with the 3 other bolts turned in all the way, the cap feels loose.
In the service manual, they show a large o-ring about the diameter of the cap, fitting around the circumference of the cap and onto the distributor body. There is another o-ring in the distributor base that seals oil from inside the engine from leaking into the distributor, about 1 1/2" diameter.
Is there supposed to be a large o-ring around the outer rim of the cap? I was thinking that the small gap might be there to accomodate it, and the bolts cannot tighten down unless it's in there.
Thanks for the reply. There's no Lexus dealer here, so after looking on-line with no results, I went to the Toyota dealer and have 1 on order - $11.50! Oh well, it should be mounted right. The parts guy was surprised it ran with the loose cap and missing seal.
Taka
08-31-03 11:07 AM
3vzfe, 93, cap, distributer, distributor, distributors, es300, inside, installation, leaking, oil, oring, problems, rings, seal
