New (to me) ES300
Old 09-07-10, 10:16 AM
Bedore
Bedore's Avatar
Default New (to me) ES300
Hello all,
I recently acquired a 1997 Lexus ES300. Really liking the car. Figured it would be a good time to introduce myself as well as post up about a couple issues.
The first is the A/C. If I put it on Auto and turn the temp **** to COLD, it doesn't blow cold and the A/C light blinks. If I manually select A/C and fan speed, it will sometimes blow cold (real cold) then stop blowing cold. I have done some research and saw that a magnetic clutch relay was to blame, but it appears to be on later models (02 + I believe). would my 97 be subject to the same issue?
Secondly, the engine appears to have some valve noise. It runs great, and doesn't stall or anything like that and I assume it to be some valve/lifter noise consdering it has pretty high miles. Is this something to be concerned with? The check engine light came on when I was driving it home, so I have to get the code read...soon.
Anyhow, thanks in advance and I hope to find much information here to help me during my ES300 ownership.
Old 09-07-10, 06:55 PM
wbudna
wbudna's Avatar
hello and welcome, Im new to the forum myself as i just purchse a 96 es300 with over 250000k miles and im having the same valve noise im going to have it check out next week will keep you posted on the results
Old 09-08-10, 07:10 PM
Bedore
Bedore's Avatar
Please do! I would be interested to see what you find out as the source of the noise.
The check engine light that I mentioned was P0141, the post-catalyst o2 sensor. Got a new one on the way for replacement.
I also was able to fix the A/C. But I do have another question. I will have to disconnect my negative battery cable to clean it and to clear the check engine light once I install the new sensor. Does anyone know if that will affect my radio function? I have read it will, and I have read it will not. My radio LCD is broken so I can't tell if it's secure coded or not.
Thanks.
pramod109
05-09-19 03:18 PM
ATrain
01-14-11 03:38 PM
hpage66
05-24-09 03:04 PM
4mula_J87
01-20-09 05:57 AM
Quick Reply: New (to me) ES300
