Diy LED Mirrow Turn Signals
Old 05-19-11, 08:50 AM
  #31
jskwik
jskwik's Avatar
thats looks real classy...will definaly be looking into this!!!! thanks great work
Old 07-09-11, 09:03 AM
  #32
es30000000
es30000000's Avatar
Originally Posted by MrGalione9
its been a WHILE since i've been here on the thread... I was actually interested, in finding out where the turn signal wire is located... therefore i can connect my side led's and see if it works... so far i've got the left side (driver) installed but the passenger is ****ed due to when i got hit on the side, and they've glued the mirror to the frame, so i gotta pry that off w/o damaging... but one at a time... so if you can, can u tell me where the location of the turn signal circuit is, so that i can connect it
I ran the wire to the trunk and found the wires coming out of the blinker and spliced into there.. you could also find those wires and then follow them to the fuse box.. your call. Hope this helps
Old 07-09-11, 03:02 PM
  #33
xXTimmayXx
xXTimmayXx's Avatar
Originally Posted by es30000000
Honestly that would look terrible. And during daylight it's definitely bright enough to see and very visible. At night it is EXTREMELY bright.
You want just enough to accent the car nicely, but not too much to throw the rest of the car off balance. . .it looks gorgeous by the way. . .a nice custom appearance too!!!
Old 08-11-11, 08:45 AM
  #34
es30000000
es30000000's Avatar
@xXTimmayXx thanks very much! It was well worth the few dollars I spent! But I just recently discovered the the last 2 LED's on the passenger side have burnt out so I will need to order a new strip for that side and replace it! But I recently cleaned up my wiring I did on the signals and I made a disconnect point right below the tweeter behind the door panel so if the mirror ever needs to be painted, or when I replace the LED strip I can simply disconnect right there, install the new LED, crimp on a male connector on the end of that wire and connect them! It made it so much easier, wish I would've thought of this right away!
Old 08-15-11, 01:39 PM
  #35
LexLuger31
LexLuger31's Avatar
very nice job!
SonomaZ
06-25-21 11:55 AM
Nomi
01-30-18 01:08 PM
cdnewton
08-09-17 04:42 PM
Deegee
Performance & Maintenance
06-14-16 02:32 PM
SerasLibre
05-05-15 06:16 PM
Quick Reply: Diy LED Mirrow Turn Signals
