What Problems Had or Have with your ES?
92 es 5 speed
1. Partially burnt out a/c display
2. SLOW windows up or down
3. Headlights/interior displays dim when i hit the window up/down button
4. Cracking Leather
5. Cupholders work for ***** lol
4. Cracking Leather
Originally posted by Rit&Booner
95 ESTach and Spedometer Needles burnt out completely
Sunroof, air noise leaks through
Rear, Right speaker dead
Squeeky noise in rear when bouncing
Squeeky brake noise even when not braking
Acceleration Hesitation
dang....my es is the same year. i hope mine don't end up like yers.
whats yer mileage?
1. power steering pump leaking- lexus blames the 18x7.5
2. windows slow
3. headlights dim b/c of braking and moving windows and coughing jk
4. rear main seal
5. liquid engine motor mount
6. cracked radiator
7. right blinker blinks fast for no apparent reason
8. Radio buttons stick
9. cd changer skips - i think it needs to be cleaned though
10. antenna motor crapped out
11. driver side door squeaks
12. brakes squeak like a ****
13. cv boot thingie, pops, knocks
14. Red indicator/warning sticker on front passenger door lock fell off.
15. Front passenger plastic light cover refuses to go back on
16. Remote key button possibly flaky b/c i have to push it a couple times
17. cupholder doesnt eject right
18. drivers side seat looks squished out to the side, like the other guy
19. floormats
20. new gold logos all the way around
21. worn leather look and feel
I think Im done but I should stop anyway....sound like I have a pos, but almost all are fixed.
2. windows slow
4. rear main seal
6. cracked radiator
19. floormats
Today my interior light quit working....can't be the bulb, since i replaced that just a couple months ago, maybe a bad connection of some kind. Also noticed that the red door lock indicator sticker on the passenger door handle peeled off. Also, the leather on my back seats look like ****. The fronts are decent, but far from perfect. Oh well, very superficial problems, ES still rules
Super Moderator
i forgot to mention:
- replaced rear struts
- front left cv boot fix/replace
- leather probs
- slow window rolling
- rattling moonroof when the cover is open but not the moonroof
- leather probs
whats yer mileage?
whats yer mileage?
Mine is 139,000. 60,000 when I bought it in 99'
I be traveling with it every year. Another problem I forgot to add was the light illumination on radio buttons are burnt out too.
I cant remember if I already posted this or not
1996 ES300 Coach ED 78K
1. Stupid seatbelt cover pannel things on passenger and driver side front fell out...(in process of getting new clips)
2. Passenger side door handle cracked.
3. Wood cracked below shifter
4. 5-10 door dings/ scratches
5. Leather old and worn out.
6. Driver seat goes to one side (like the others)
7. Cup holder wouldnt come out. (fixed)
8. Wood trim on front doors looks like crap. (back doors looks original)
- Most are just visible. The engine runz like a top. NO hesitation, well there was. This 2 second thing when you floored it. I fixed that up tho. Gunna get the windows tinted and hopefully it hails soon so I can get some more dings....then I can finally take the car in and have em ALL taken out. New paint in a little bit..
hail tonight? I didnt think it was supposed to storm..hummm haha I got hit by some hail the other day when it stormed like all day, got like 2 inches of rain. I went home and checked but there were no new dings.... : / haha youve got the idea about the insurace company man
My 95 has:
burnt out ashtray bulb
burnt out speed needle
passenger door exterior rod handle dissconnected (courtesy of nissan motors)
Only major problem my rides had since 95 is an o2 sensor replacement
1994 with 150,000 miles - Had it for the last 15,000 miles
1. Valve Cover Gaskets Replaced
2. Front & Rear Suspension replaced
3. Torn Intake Hose (replaced)
4. Speedometer, Fuel Needles dying
5. Squeaky Brakes
6. Driver Seat needs to be re-sewn - it has a tear in the seam
7. Cigarette lighter popped out- gotta hold it in to get hot
8. Seatbelt clip on driver side
9. A/C button isnt illuminated at night
10. Needs new motor mounts
11. Check Engine light is on because EGR valve flow is insufficient (Exhaust Gas Recirculation)
12. Driver's Side door panel is kinda loose at the bottom and makes nasty noise when door is closed
13. Transmission Fluid Flush
Car is in good shape for 150,000 miles though. Still runs fine and looks good.
5. Squeaky Brakes
98 ES with like 44/45k miles on it....all ive had is my charcoal canister went bad and i had to pay a smooth 620 to get a new one....this just happened a like a week and a half ago
What I have replaced
I have a 93 ES with 120,000 miles.
This is the recent catalog of things I have replaced:
both front half shafts
upper and lower motor mounts
rear right window actuator
hood struts
rack and pinion steering
rear brake pads
air conditioning compressor twice!
right rear wheel bearing
antennea mast
valve cover gaskets
tires
spark plugs
Things I need to fix:
struts all the way around
left rear door lock actuator
right rear door courtesy light switch
front rotors
timing belt with cam seals
So far this car has cost me quite alot! So much for Lexus reliability......
hood struts
rear brake pads
antennea mast
valve cover gaskets
tires
spark plugs
front rotors
98 ES30045K
already change 3 battery by the dealer
new alternater (38K)
both side door piller ( the thing goes on between your window. the black thing)
cd changer show error so they replace anther one 15K
upper control arm brushing change 30K
Cigarette lighter don't work so they have to replace twice, but now it's not working again ( non smoker)
seat belt change (because it won't go back) 15K
this remind me of all the bad thing...........
