Kickers CVR in Ported 1996 *Check out*
#46
i recently installed the 2 farad cap, and it doesnt completely fix the problem but it does in fact help sound quality on deep notes. My next step is to get a yellowcap because my battery is in bad shape. Possibly do the big 3 sometime if i can find where the engine block ground is...but for the most part, i am pleased with my cap.
#47
name ONE "world class competitor" running caps? no one dose in the competition world, because they are worthless. ive been competing for 5 years, and have yet to see a cap, except by first timers who are mocked for thinking that their cap is helping them.
big3 should have been done LONG before you purchased anything..... and any bolt on the engine block can be used, i said that before....
#48
#50
yea. i finally figured out the alternator harness problem. its not a harness, just a cover. and i was just concerned about the engine block wire running too hot...but a good bolt i see are above headers. it looks pretty sollid. cant i just get 0 gauge wire from home depot. or reccomend smaller strand audio wire. ultimately it will be the same result right?
#51
Yea 0 gauge is often used as it is the thickest wire that a wide variety accessories are offered for in car audio. If you plan to upgrade your alternator or battery it is recommended.
#53
subs are 2 custom 18" sundown nightshades off a stetsom 11k2d
mid/highs i have 4 8" mids, 6 6" mids, 4 3" horn tweeter and 12 1" dome tweeters, witch are run off of 2 arc audio 300.2 and 1 300.4.
highest strand count= better cable. go with knu koncepts or shok cable, best cable for the $
there is a harness witch you should not mess with. then there is a bolt, like i said. you just connect it to the bolt. heres a image of the es300 alternator showing where to connect it. http://img833.imageshack.us/img833/3871/94638117.png
and home depot 0 awg is not good, its solid stand. besides car audio cable, your only other choice is welding cable, but its more expensive then audio cable is. like i said, use Knu or shok cable, there cheap and are some of the best cable ive ever seen.
#54
pyroibw- you are an idiot. two of us have stated that caps have had a positive affect on our systems. nobody is saying that the big 3 along with alternator and battery are not important. stop trying to show us how f-n smart you are because it's backfiring on you. go ahead and band this piece of work since he's not trying to help anyone - he just wants all of us to understand how brilliant he is. The day I became a man was the day I woke up and realized I don't know everything. pyroibw hasn't realized this yet. By the way pyroibw I can tell by your list of equipment that your vehicle gets loud, but I could get better SQ out of 1/10th the equipment you run. have a good day.
#55
#56
For whatever reason this cap sitaution is a hot topic. Lets just agree to disagree I am on the side of running a cap and will def be running a cap even if it is jus for looks.... Although I believe that it helps my system... who knows maybe us cap loving guys are just the lucky ones whos caps were defective and we benefitted from them instead of having negative effects from it. By the way pyro nice system and audacity i get what your getting at but pyro has been pretty good at not being that "electronic engineer guy" so cut him a break please. https://www.clublexus.com/forums/es3...and-alarm.html
Anyways what do you guys think of my system. O I have a 2.5 farad cap which I love. It has digital voltage display. Auto On/ Off on the cap maybe thats why it only draws from the battery when my amp is on.
#57
In certain applications a good cap serves a purpose."CAPS ARE USELESS!" and "caps are lies, they do nothing. they cover up a problem, not solve it." are NOT true statements.
Bottom line is that if you're going big (be it SQ or SPL) with a sound system you're better off starting with an upgrade to the big 3, upgraded alternator, and good batteries as pyroibw stated earlier.
There are quite a few batteries out there now that put the Yellow Tops to shame. XS Power is probably the best at the moment.
You need a good install including sound deadening and then comes equipment. The install is AT LEAST as important as the gear used-probably more important than the gear.It's always a good idea to research installers in your area before you pick one if you're having the install done at a shop.
#58
#59
#60
