Bluetooth addon - '03 ES w/ Nav
Has anyone added a bluetooth kit to an 02/03/possibly 04 ES (if the nav is the same gen)? I'm toying with the idea of adding one to my fathers 03 ES with nav as a christmas present. I'm talking about a nicer one that wires in through the existing audio and has a discrete, clean look not a cassette adapter + cigarette lighter mount type. Any info you can provide on price, brand, installation etc. would be appreciated. Thanks
There are a bunch of Blutooth kits out there, but they can be a pain to wire up if for example you want a device to run through your sound system. You might be better off replacing the Nav Head Unit with a nicer one that has a blutooth feature built in. That way you wouldn't have to do much at all except change the harness. But if that's too much for you than get one of these, and wire it up to the battery:
http://www.crutchfield.com/p_333CK31...k.html?tp=8395
This is the unit I will probably be investing in next Spring:
http://www.diceelectronics.com/media-bridge-info
I hear/read good things about it, seems to have good integration to our head units.
dvdchance
06-30-19 11:40 AM
Harvi
08-16-10 06:48 PM
