2ES Can lights be modded to turn on upon unlock?
I have a 1995 ES, is it possible to mod the interior lights and/or headlights,brakelights to turn on when the car is remote unlocked. This has been asked before on these threads but no answer was ever given, so im trying again. Thanks.
any car audio/alarm install shop should be able to add a relay to your oem keyless entry. most aftermarket alarms and remote starts come with an output just for that but its an easy add on to most oem systems.
Thanks for your responses guys but I guess I should have specified that i want this to be a DYI. I like inexpensive projects to improve my car but im not looking to spend any money on this by taking it to a shop.
So can this be a DYI?
If the answer to any of these questions is NO. I would recommend spending the extra money to get it done right. I have seen a lot of simple DIY jobs, done terribily wrong and costing folks alot more than it would to have intially done right through the shop.
However, if you feel comfortable don't let me scare you and it really isn't that hard with the right equipment and know how, it most certainly can be a DYI.
I hate to answer a question with questions but.... Are you comfortable removing panels in your car? Are you into car electronics ie resistors and relays? Do you have the equipment to test wires? Do you have access to wiring diagrams? Do you have the equipment needed to make this work ie, keyless entry system or alarm/starter with extra ports?
I have the oem keyless entry system, im not sure what you mean by extra ports but i can answer yes to the rest I just dont know where to begin, although i can read wiring diagrams and ive taken my share of panels apart, if this is much more than a splice/reroute job, then it may be too much hassle for me
nosurprise
07-22-12 12:52 PM
