Car won't stay on after disconnecting battery
Old 10-28-10, 07:48 PM
rickyp39
rickyp39's Avatar
Default Car won't stay on after disconnecting battery
Everytime I disconnect the battery on my 2003 es300 and then connect it, when I go to start it it turns on but it immediately dies. So what I have to so is hold the gas and maintain the rpms higher and when I let go of the gas it will hd a very very low idle almost sounding like it is going to turn off but after ten minutes roughly it goes back to normal. I know that cars have to relearn their idling system but is it that much of a pain everytime I have to disconnect the battery?
1MZ (12-16-22)
Old 10-28-10, 08:59 PM
KLF
KLF's Avatar
Yes, the ECU has to reset and re-learn the sensors, re-calibrate, calculate the timing, calibrate the injector rates to get the A/F ratio correct at the O2 sensors, etc.
How often do you disconnect your battery?
Old 10-28-10, 09:33 PM
rickyp39
rickyp39's Avatar
Oh that is quite a few things. Well for now I am done disconnecting it but I was replacing my battery and alternator so it was becoming quite frustrating. However something weird occured after I disconnected it. My trac off light and my vsc light turned on on the dash and I can't get them to turn off. It rides fine and feels completely normal. Is there anything I can do about that?
Old 10-29-10, 04:16 AM
KLF
KLF's Avatar
Look around the air box behind the battery. My guess is one of those several vacuum lines got unplugged. It's happened to me, same symptoms, easy thing to miss.
Old 10-29-10, 01:31 PM
BoostedE21
BoostedE21's Avatar
That's what I would guess. The car shouldn't go into retarded mode if you just swap out the battery.
Old 10-29-10, 03:30 PM
rickyp39
rickyp39's Avatar
I checked the lines and they all are plugged in properly. I wished it would have been that but the lights remain illuminated on the dash. Any other suggestions or ideas ?
Old 10-31-10, 02:32 PM
GoodRevs
GoodRevs's Avatar
I had the same thing happen to me when I went to replace some bulbs in the climate control console. First time I ever did any work on my father's '03 ES and when I went to start up the car the same results happened to me, scared the **** out of me because I wasn't familiar with that happening on any car. I'm still not sure what is entailed in performing an "idle relearn strategy" with those ES's?
Old 10-31-10, 08:16 PM
rickyp39
rickyp39's Avatar
Really? What did you do to keep it running?
Old 12-16-22, 07:31 AM
1MZ
10th Gear
1MZ's Avatar
I did this to fix this issue -
akafixture
03-12-17 02:23 PM
dxerg3770
ES - 6th Gen (2013-2018)
46
03-15-15 08:16 AM
Solo2
12
12-02-12 10:23 AM
jstjohnz
10-15-10 10:24 PM
kqt2ktval
12-12-06 07:42 AM
Quick Reply: Car won't stay on after disconnecting battery
