P0420 and P0420 (P)
P0420 I would do the sensor first.
Its cheaper than the cat. and make sure to buy an OEM sensor.
You wouldn't happen to have an exhaust leak, would you? That would also trigger it.
-Try clearing the code,and see if it comes back.
I fought that code for a while (clearing the code, via obd2 scanner) until one day, I repaired a nagging exhaust leak. No more P0420 after that.
I don't think it hurts your car running with a P0420, but I don't like any CEL's lit consistantly for days on end.
-P could mean the code is Pending
Hope this helps...
Hope this helps...
the thing was when I bought this car the Check Engline lights, etc lightbulbs were burnt. So when I was repairing the green light (indicating your headlight is on) I repaired them as well. Basically I been trying it since Fall of 2009. My tachometer starts at 1.5K as well so I'm guessing its the o2 sensors? I haven't seen any leakage as well.
http://www.obd-codes.com/p0420
chi123
08-14-12 06:27 AM
