97 es300 BRAKE indicator on Dash won't turn off
Old 11-22-10, 09:12 AM
rws
rws's Avatar
Default 97 es300 BRAKE indicator on Dash won't turn off
All weekend no problems, then going to work this AM the car starts normally but brake indicator light on dash won't go off.
What are my options for checking this out?
I checked the brake fluid -> OK not low
Does driving in Reverse and slamming on brakes adjust brakes?
Do I need new brake pads?
Any help truly appreciated.
RWS
Old 11-22-10, 04:13 PM
QuachmanES
QuachmanES's Avatar
The "brake" light alone just means that the parking brake is on, unless there is a different brake indicator light.
Old 11-22-10, 07:18 PM
sphillips
sphillips's Avatar
Check parking brake switch to make sure it is not stuck "on".
Old 11-23-10, 12:26 AM
renatodato
renatodato's Avatar
What do you mean by brake fluid "not low"? Double check fluid and make sure you're at the maximum level. Usually the light goes on if brake fluid is near the low mark, not necessarily below the minimum mark.
Old 11-09-16, 08:03 AM
mugencivic
mugencivic's Avatar
Does anyone know the location of this switch? I'm having the same issue and I use my foot/e-brake every time I park. I noticed that when i tap the lever with my foot it turns off. Do I just need to change the switch?
Old 11-11-16, 10:12 PM
yeskay
yeskay's Avatar
RWS
did you check the brake bulbs. they might have blown out.
Old 11-12-16, 03:03 PM
PFB
PFB's Avatar
Make sure that your hand brake is released, than pull back on it with your hand. See if the light now goes off.
Old 11-12-16, 10:34 PM
808mcv20l
808mcv20l's Avatar
It's gotta be either the brake fluid is low, or the float is broken, or the ebrake switch is stuck.
Or a combination of those.
Cruisin101
01-23-18 01:16 PM
dalerk
RX - 1st Gen (1999-2003)
01-12-18 08:02 PM
flossabe
09-25-11 02:47 PM
Emilio253
SC- 1st Gen (1992-2000)
08-04-10 12:15 PM
BamPearl
02-09-10 02:52 PM
Quick Reply: 97 es300 BRAKE indicator on Dash won't turn off
